Since I just (yesterday) did brakes and a knuckle job on the grocery getter '97, my dad has offered to pick me up the radiator that my '93 dearly needs. I will install new hoses with the radiator.
I'm aware of the seals/gaskets that are much easier to replace with the radiator out on an F/2F motor, but I am clueless with the 1fzfe.
The truck leaks quite a bit- I've decided to knock out gaskets and seals as it is convienient. Well, having the radiator out should make a few seals convienient.
I assume the front main seal is just a matter of pulling the crank pulley and balancer, like an F or 2F. Are there any timing chain/belt/gear gaskets? (not sure which one it is with that fancy DOHC)
Anything else yall think I need to do while in there? I've done all this on the old cruiser 6's, not with an 80 though.
Thanks.
Thanks.
