I recently posted a thread talking about how I thought a blew my head gasket and was probably going for a total engine rebuild. Even had The Conversation with my wife about how we would need to drop at least 6k for the job.
Then the mechanic went in for a full look and reported back the HG was fine (I DID see tiny bubbles in my reservoir....), where the cylinders were not cleaned as though coolant had hit them. Also noted oil in the intake. I was very confused, as what brought me to the mechanic in the first place was the following....
- Loooong max up a mountain at altitude caused the engine to bog down and begin billowing smoke out the tail pipe. I've never seen an HG blow, but it looked for all the world like it was the HG, based on descriptions here. When I popped the hood, thought the coolant looked a little oily. Maybe I was seeing things. Noted the dipstick had popped itself out of its hole.... Thought I had lost a quart or two of oil during the climb....
- SC has a 2.8" pulley with a meth kit set to inject at 5 PSI (low spray) with max overall boost of 6 PSI. Timing advanced to about 7 deg. Never any knock or codes.
- Was able to drive up to the pass, do our family hike, then drive the whole way back home with rough idle but otherwise quite drive able.
- No codes....!
- Next morning, truck belched one stream of smoke, but then ran fine and even cruised on the highway with no issues.
