I've been trying to find a resolution to the starter issue and I have had no luck so after asking around many places I thought to check here.
ISSUE = 1995 SBC 5.7L starter will not engage the flywheel. After trying to replacement/refurbished starters from the local Auto Zone and had no luck I bought a brand new starter (upon their recommendation ). The starter was noted to be a "Shimless" starter. I bolted it straight up to the block and have no luck with the two sprockets aligning. The starter sprocket will push out and attempt to engage the flywheel ring gear but the mesh between the two will not align. Sounded like a spacing issue so I got a 3 shim pack and tried every combination from the thinnest shim to the thickest shim, then various combinations of all the shims together and still could not get the two sprockets to align and crank over.
I spoke to a few people and I cannot find an answer to solve the issue.
Any thoughts??
Any thoughts??
