If they're winter tires...like crap. But I guess it all depends on what your definition of 'perform' is. Regardless, you can probably get a few bucks for them on CL.
I'm going to get wheel spacers eventually. May not be for anything other than looks, but that's fine with me.So much better with the stock wheels.![]()
Well you all have talked me into keeping the AHC...at least for a while. My question is what is the better option? The Slee override switch or the mod that is posted in the FAQ? Any pros or cons to either one?
So the metalizer is a top coat for whichever color plastidip you chose. Mine is the gunmetal grey plastidip with the graphite metalizer. That's the closest you'll get to a gunmetal grey.
The graphite metalizer looks good over black too. It's just a bit too dark for my liking.
I have that Slee switch with the the Diff drop and t-bar adj installed by ACC and am very pleased!
Did you address the rear coils? If not you'll likely have premature failure if you keep it in H all the time.
I'd be curious to see what your pressures are.
I also tried the headlight restore, but my headlights are cracked/pitted from the inside. So I will have replace the whole assembly, both low and high beams. Guess I need suggestions on HID assembly kits. Not bulbs, the whole thing.
How long between base coat and metalizer did you wait to spray?
Where are you guys getting your plastidip from?I wait about 10 minutes between all coats.
