Hello,
I have been following this site for a couple of years now, I own a '96 fj80 and '74 fj40. I found that what ever problem I've had in the past from; check engine light (oxygen censor) to break adjustment the answer is always in old threads in your forum. So I would like to say Thanks.
I'm like most guys who hates to ask for help, but for my sanity sake and my marriage I'm going to bight the bullet and do so now!
I've recently swapped my daily driver from my 80 to my 40 for the summer. When I put the 40 away for the winter last year it was in desperate need of a tune up and a carb rebuild. Fast forward to this year, 2 week ago I completed those tasks. I put a new manifold gasket on, new points, condenser, plugs and wires, and then rebuilt the carb, I'm not a mechanic but fairly mechanically inclined and enjoy doing things my self. After setting the timing and adjusting the carb according to the haynes manual I thought I was in business. No such luck. The darn things running rich. It will run perfect on the short early morning commute to work but after it warms up hear comes the gassssss. It begins missing under load. I would guess at about 1500-2500 rpm. much like if you tried to drive with the choke on. I've check my vacuum lines and believe their hooked up properly, the float seams to be adjusted right (fuel is at dot level in the window). Double checked the primary jet and secondary jet placement. The one thing I did notice was a discrepancy with my venturi's from what the manual says. Mine are Identical, there is no large or small or what I can see that would distinguish them apart in any way. Could this be my problem? The carb has signs of being rebuilt before, so I know someone has been in there. This is my last ditch effort before I start searching for a local shop for repair. Any input is greatly appreciated.
Thanks again
Gavin
Thanks again
Gavin
