Running Hot
BamaHeel
Intergalactic Champion
Birmingham
So I got my oil changed at the dealer yesterday 137,000 no issue of note to date. Have had no issue leaving. Drive around rest of day problem free.
Today drive about 15 highway miles to destination, stay for an hour and on return trip AC goes Luke warm, look at temp gauge on interstate and just below red.
Slow from 75 mph to 60mph and temp starts dropping with rpm's.
Approach a hill with a steady, slow, uphill climb and temp shoots up to red.
First thing I checked was the radiator and overfill level and I'm good.
Get home, search, and after conferring with Bamachem decide it's the fan clutch which spins freely. Get a new one, install; try same hill after new fan clutch installed and temp shoots up. AC heats up.
I haven't puked fluid so mechanical water pump working so only thing left is thermostat, correct?
Any other ideas?
If the fan clutch and water pump are working and the coolant level is ok, I'd agree with new thermostat next.
I'm a big fan of preventative maintenance thermostat replacement. Seems like when it goes bad, it usually blows up the radiator.
I would not suspect the fan/fan related parts if it's overheating at speed. The fan only really comes in at idle/low speeds.
If you're not losing coolant...
Thermostat would be a good one to check.
Have you been mudding lately? It's possible your radiator is gunked up and unable to shed heat.
I haven't been in the mud in a while. I'm doubting thermostat because the fluid in the radiator is very hot. I thought bad thermostat equals hot engine and cold radiator?
Is it possible for the water pump to fail with no outward signs of failure? I. E. Not puking fluid?
Not sure.
New idea on thermostat. What if it's stuck open instead of closed and not slowing water down to cool off so it's just circulating hot water?
New thermostat installed and back to normal. Drove around for a while with ac on COLD on interstate and up and down hills never got above mid way on temp.
Thanks to everyone for their input.
Not sure.
Glad you got it fixed. Nearly ever catastrophic radiator failure I've seen on a 100 was due to a failed thermostat. So it would have to build some heat and pressure somehow. I'm guessing it stays closed stopping the coolant flow causing engine temps to rise and heat and pressure to build up in the radiator.
