Rubithon Bound
Air down to the pressure you'll be running on the trail, then check the clearance between your UCA and the upper inside portion of your tire. If its too close for comfort, run the spacers. Otherwise, don't. I'm running 1" BORAs because the 315/75/16s are 12.5" wide and I had about .75" between the UCA and the tire. I didn't want to flex a side wall into it and risk a puncture.
Post photos and video! Can't wait to hear about this.
That's one good looking truck,I really like your front bumper!
Thanks Don. Truck has changed a bit since you last saw it. Glad you steered me toward Dissent Offroad. Did their rear too but you cant see it in the picture. Even got a set of their pre production full skids. Superb craftsmanship. We need to get together for a trail run now that the snow is melting.
- OME shocks are in good condition, and there is a Slee diff drop. I may consider getting a new set, swapping them out, and keeping these as spares. Unless anyone has some used ones they want to sell.
If you are looking at new shocks, I would consider going with a different brand. Just replaced my OMEs with Tough Dog and the truck rides so much better. Rears are adjustable too so its easy to dial in the right level of dampening depending on load.
If you just need spares, I'll bring the OMEs I just took off and you can have them. ..might cost you a beer.
Someone mentioned the ARB front bumper being too bulky...I think it will be fine on the Rubicon. Rear gets smacked way more.
Though I don't have them yet, the Timbren bump stops (mentioned earlier) sound like a great idea too.
Finally we have some decent weather, so yes lets do a run sometime, now that I got my heater T's completed.
The spacers, I'm not committed yet to run on them, I'll see how much the 1" spacer changes the spacing on the tire. Right now, the tire is well tucked in. As far as the front bumper, I'll have to live with it as is.
- Spare tire is on a rear swingout (Kaymar bumper)
Will look into the Trail Taylor Rear sway bar links and lower control links. I am also considering the HD control arms.
Spacers - The issue is not where the tire is in the fender, it is the width of track on the ground, 1" spacers make your track 2" wider. That means in the narrow sections of trail you lose 2" of tire placement option, may not sound like much UNTIL you have run Rubicon. Then on top of that, impact on turning radius. Someone posted concern about sidewall flex contacting UCA, not an issue with your tires. I run 295 with no spacers at low pressure a lot with no issues. Sure I have contact on inboard side of rear fenders at extreme articulation, but only at low speed and never damaged tires. I have spacers and the only time I use them is to put chains on all four tires for snow. Might want to think about this, spacers add more leverage to suspension, so impacts on obstacles are amplified to steering rack, ball joints and CVs.
ARB bumper - Understand run what you have, you may need a little extra rock stacking.
Shocks - If they are in good condition, probably okay. Air bags in rear springs would help, you are going to be heavier than normal. Bags are adjustable, cheap and easy. Dropping off big ledges nice to have rear sprung stiffer.
Spare tire on Kaymar. Saw that, my suggestion is to move it higher if possible, some swingout tire mounts have adjustments. Dropping off big ledges, tire slides down ledge, putting stress on swingout.
Maybe we can link up for lunch prior to Rubithon when you are getting your skidplates.
Subscribed and looking forward to the post trip photos and update!
I saw a post he made in the pic thread saying he did it. Excited to hear back!
Rubicon Trail Completed successfully, with no breakage other than some new badges of honor on the LC. I don't think anything I have been on even remotely compares to the Rubicon, once you hit the trail, it is nearly nonstop obstacles. In fact, the definition of obstacle gets redefined because it seems you are always on some obstacle, and only the really big ones that slow everyone down become the obstacles.
I was put 2nd to last in the Wagon run, I believe anticipating I may have issues, after all, it was my first trip on the 'con, and not many hundy's have been down the trail. @JohnnyOshow22 got the duty as gunner/spotter of getting me through the trail, a job he did splendidly. After the first day, we camped at Buck Island, and shortly after I rolled in, there were quite a few people that came by to get a look to see how it handled round 1.
At that point, I had 2 new scars. The first was the rear-driver side door got a ding from "thousand dollar (aka million dollar) " obstacle. The second, a dent in drivers-side quarter panel, right in front of the slider was on a small rock garden, not difficult at all, but it was in a tight squeeze between trees. I tried to squeeze next to a boulder going around a bend (where she barely fit through), and the rock below me shifted, slamming the quarter into the boulder. Had I been an inch or two more forward, it would have hit the slider.
On the second day, I had quite a bit more damage occur. Both sides of the front bumper took a hit on a boulder after slipping off another, pushing the ARB into the quarter panels. Also, on the rear passenger, the same thing happened to the Kaymar.
Other than that, she spent a whole-lotta-time on her sliders, and belly plate. The Dissent skid plates held up marvelously, and I sustained no other damage below, other than a bit of dents, scrapes and scratches on the plates themselves. This weekend, I'll be cleaning up down below, and get pics of any dents/dings I see below that I think are new.
For the record, I never once had to use the winch, or be winched/tugged out. But there were at least 3-4 times I did get hung up, and had to get a few extra rocks stacked to get me out. Also, @Jetboy let me use his maxtraxx once when I got high centered on a ledge shortly before Rubicon Springs.
Overall Recap:
Do I plan to do the Rubicon again: YES
Would I do it again in the hundy: No
Do I regret taking the hundy this time: No
Is the 100 capable of getting through: Absolutely, no question
If anyone is considering it, I would say you must have Skid Plates, Front & Rear bumpers and sliders at a minimum. If you have a 40, 60 or 80, chances are, if you don't have a part that breaks, someone will, but with the hundy, be prepared with an extensive list of backup parts, as no one will have parts to share with you. Also, be prepared for extensive body damage, I was prepared for worse, and felt I got out relatively lightly.
A stop at Arnold's Rock
First video I have: Big Sluice
Here is a google Gallery of the before & after for my truck.
https://photos.app.goo.gl/2qWjCkEYJJBqej5S7
PS: I'll keep adding links to pics/vids as I get a chance to process them.
Cool!! Think I would have rather run no bumpers though, than bend yours up. ARB and Kaymar are not built or designed for that type of wheeling. Unfortunately you found that out. Nice work tackling that trail.
That's awesome man. Use the lockers much?
The lockers definitely got a lot more use than I have ever done before. In general, I left them off, and went through the obstacle, if I got stopped or hung up, I would back up slightly and try again with the lockers. Also, on the bigger, well known obstacles, most of the time I would pop them on as requested by my spotter. As I was with a group, and wanted to keep things going, I didn't feel the need to take on every challenge to see if it could be done without them, just wanted to get through in a timely fashion.
I can't agree with you on this, as I know for sure, the front specifically, if the bumper wasn't there, I would have taken a load more damage. I would agree with you that these two types of bumpers aren't designed for this type of thing, but they did well. Now there are several vendors that make much sleeker bumpers that help with approach and departure angles, that would have taken much less abuse.
I have only done the Rubicon in a Jeep. Mighty brave of you taking the 100 out there. Great job!!
Awesome report. Do you have any more videos on your rig on the trail?
So far, just the one above. I don't have much videos that I took myself, other than gopro timelapse/video from the top of my roof rack, which I am working to put together. A few others may have taken video/pics of me, and as I go through the Rubicon media, when I find them, I'll pull them all together and post them here.
Thanks man
Hell yea! The 100 Series is definitely more of a gear hauler/overland rig than a rock crawler. Takes balls to do what you did. Well done!
@JohnnyOshow22 is a cool dude, he used to live in FoCo and was part of the local Toyota club here... Unfortunately he lives in MT now.
Keep the videos coming!
Good on you and thanks for the update!
My 100 has its fair share of body damage trying to keep up with the rubicons and defenders we wheel with up in VT. It's not the right tool for the job but it will make it.
I had a custom front tube bumper built after my ARB Sahara kissed one of the front fenders. It's much nicer for more serious wheeling and tight spots.
I’m glad you came out just fine. Battle scars are there for conversation piece.
We went the week after you guys did, schedule conflict. Our Hundy did great. Came out clean this time around. Last year we had our gash, due to an impatient driver.
Good job @slimbuddha.
How was that left plank on that decision tree? We wanted to take that instead of hugging the tree but I guess running the trail after rubithon made it very challenging.
