Hello All,
I'm hoping for some help on my brakes. I've been chasing multiple brake issues on two different Cruisers. It's so bad I've resorted to driving a Honda.
The first is Lilly, 1988 FJ-62, 300k miles on a stock drivetrain. Because the drive train was tired I swapped axles from a different 1989 FJ-62 with 200k miles. The axles and attached brakes functioned flawlessly before the swap. Now the rear drums are dragging so bad they overheat. When installing I loosened the park brake cable and shoe adjusters prior to driving and set the shoe gap by cycling the park brake several dozen of times until the pedal travel felt good. I've bled and bled and bled the system including the master and the LPV.
Lilly has other problems which may or may not be related.. She has been overheating after a few miles and has no power between 1300 and 2500 rpm. If you can coax her to 2500 she runs strong until she overheats. On one short run I noticed the pedal travel was getting shorter. 2" turned to 1" which turned to 0". Touch the pedal and she stopped hard. Even with this she was still rolling from a stop if the brake was released. A mile later back at the shop I could smell the brakes (and the mildly overflowing antifreeze). Idling in park, I pulled the vacuum line into the booster and she immediately rolled forward a few inches until the transmission Park brake caught.
Subsequent short runs with the LPV tied up against the frame resulted in hypersensitive front brakes. With 32" tires she'll lock up the front with only a light pedal. The rear will lock up by pulling the E brake handle hard.
I've never hear of a booster failing in this way - locking up incrementally.
The second is Frankie, 1987 FJ-60, 200k miles with new Toyota (almost) everything, an Oz FF rear axle, 4 Runner calipers on the front. I fixed her until she broke. She was running well until I swapped in the FF rear axle. It had been underneath Lilly for several months (but only a few miles) and when I tried to adjust the shoes the drums were warped so badly they had to be replaced. (I've tentatively attributed the warped drums to the axle being under Lilly and damaged by whatever ails her.)
Since the master had a small leak I got a new Advios (Aisin) BMT-022 and upgraded to the 4 Runner booster (A1 Cardone) and bled the system.
Now the pedal is respectably hard with the engine off. But when the engine is running the pedal has to be pumped up. 3-4 pumps results in a firm, high pedal... for a few seconds... then it slowly drains away to the floor.
No leaks. Not anywhere. I even pulled the drums to look. The master is dry, even in between the booster. And the reservoir stayed completely full.
Since A1 has such a stellar reputation, I swapped in a known good booster from an '89 FJ-62. No change.
Is it possible the master is bypassing internally? Or through the proportioning valve?
Thank you all in advance.
