RTH Caliper bolt in a jam Helping stranded cruiser (1 Viewer)
musthave
Doc says I'm 1 in 120K. Lucky?
GOLD Star
Florida
When in a jam, I know there are a few locations on the Cruiser that have the same m6x1.0 pitch x 30mm long on the threads and 35mm overall bolts that can be taken out and used for the calipers.
Trying to help someone who is stranded, but I don't recall where those other bolts are located.
Anybody?
Try the wiring harness bolts @ top middle of the firewall.
Edited to add that they are the heater valve bolts
Bolts that hood the sunroof motor in place i think. If I remember correctly.
They're a m6x1.0 pitch they'll be big. Can't recall where to find 2.
Recovery loops under the bumper are big bolts. Don't recall if they are too big
Are you sure you need M6x1.0x35mm? They are not big bolts. Long for a m6 but not big
The 2 bolts that hold the caliper on top and bottom sides. 17mm head. I believe M6x1.0 but could be wrong. On the trail, sparse internet.
Sorry, I was thinking M6, but was completely off. Yes, let me see if it has tow hooks.
No luck with the tow loop bolts. Grabbing bell housing bolts now.
Glad it worked out. 💪
I realized after posting, my scenario was with a 1HZ powered cruiser, but I was fairly sure the bolts are the same
Bellhousing bolts to the rescue. Curious what other bolts are the same that will work in a pinch. Always good knowledge.
