RPM sensor help (1 Viewer)
Slovakia
hi every body
im planning on changing my instrument cluster from the very simple one with only speed, fuel and engine temp to one with oil pressure, voltage and RPMs,
i think i got everyting sorted out apart from rpms so far
for the oil pressure i need to change my oil pressure switch for oil pressure sensor but i still need to verify to thread on this, so if anyone could help me i will be really gratefull
next thing is the rpm, first i need to verify whether my pump has threded hole for the sensor because from what i read already there were some pumps without it and the wiring, from the sender there goes 2 wires and my question is if the polarity matters so i wont fry the rpm gauge in the instrument cluster
thanks in advance for all your answers,
it appears that the pickup sensor is just a magnetic pickup.
might double check it for diode when in hand
