MoJ
Moderator
(94 1FZFE w/130k miles)
Last week as I was backing out of the garage the engine began to stumble and shake. It sounds/feels like it's running on 5 cyl. It does this in D or R with or with out the brake applied. The RPM's vary only slightly from idle with each quick shake. The shake increases in frequency with RPM. If I put it in N or P and let the RPM's climb a bit it starts to smooth out but still isn't right. It doesn't die. No CEL at first but after a few start cycles I got a code 25 - Lean. The truck was fine the prior weekend when I drove 250 miles.
Since this started I've replaced the plugs, wires, dist cap, rotor. Nothing out of the ordinary was found on any of the plugs and they looked fine for 30k miles. The main intake hose is new. I disected and carefully inspected the engine harness were it passes by the EGR. Everything looked great. (Not a fun job btw)
Other background:
Truck sits a lot. I usually only take it wheeling or to pick up stuff for the house on the weekends. The fuel might sit on E for a month. It's slightly above E right now. The head gasket was changed as PM at 125k miles. The TB was cleaned last year and most vacuum hoses replaced at that time. Truck has always been very reliable.
I'm heading out now to change the fuel filter but I'm doubtful that will fix it. Injectors are of course a possibility but surely there's something else I can do before tearing things down to that point.
Any ideas are appreciated.
Thanks,
Jason
Other background:
Thanks,
Jason
