Rocker Arm Assembly torque ?
My Adobe is down right now and I cannot access my FSM on My computor or at birfield, and my hard copy is wiht my head that is getting a valve job. Can someone give me the torque specs for the rocker arm assembly bolts?
I think I found some of my oil blowby problem as the exhast valve seal on #1 was not pressed on and had lifted up and was not sealing at all.
Thanks Myrle
Thanks Myrle
to 13ft-lbs after several passes. I take it you have the sequence?
hth's
gb
hth's
gb
Got it.
Thanks Greg
Not very tight.. I broke on of those off in the head %^&(*& good thing it had some sticking out :)
