Right door flies open on minor bumps, lock worn?
South America
So I put some WD40 on my door locks the other day, and now my passenger door flies open / unlocks almost every minute while driving.
I took the door panel off and and checked the lock, looks like I can easily turn it with a plier or a screwdriver even when locked. Is this a sign of a worn door lock? A common thing for FJ40s?
Is there an easy fix or should I replace the whole thing?
How is your striker adjustment? I'd look there first.
If that is adjusted well, I'd suspect something in the lock cylinder is going. @ToyotaMatt should be able to make you a correctly keyed lock I would think.
Thanks - the striker (thx for helping me out witht the right word!) adjustment looks fine, but am I supposed to be able to just turn it relatively easily with a plier tool? I would assume if it's locked I shouldn't be able to?
Good read here:
