Rig turns over but dies, RTH
Aright, I got thick skin and I ain’t to proud to ask for help. Say what you will, I just need some direction.
Full disclaimer, amateur hour up in here right now.
I sea foamed sprayed my rig through the air intake.
I followed the instructions but the straw got caught on the ribs of the hose and did not spray directly onto the throttle plate. It ended up pooling and, I think, getting sucked into a passage on the side before the throttle plate.
My wife was on the skinny pedal keeping the rpm’s at 2k and it died. When I took the intake hose off, I saw the straw had gotten caught and the sea foam pulled.
It currently turns over, roars to life and then dies. If I pump the gas, the rpm’s shoot up and it then dies. It’s only alive for like 3 seconds.
It’s currently dark and 20 degrees right now so I am waiting till morning. I am hoping, maybe, some of it will evaporate and it will start up in the morning?
Obviously it’s not hydro locked, it’s turns over. it seems like it’s starved for oxygen. I believe Something is reducing our restricting assured flow and my gut is telling me the sea foam got sucked up into the thing circled in yellow.
I am not near my computer which has my fsm and having to trouble googling what ever that thing is.
Anyone know what this is? Ideas?
Maybe replace the Mass Airflow Sensor?
Some years ago I over-wetted a K&N filter on my 80 and the oil coated the wire whose cooling sets air/fuel ratio. It was similar to what you describe. I sprayed a cleaner on it and never regretted going back to paper filters.
I think that thing is like a baffle or resonator to quiet the induction noise down. Id probably take the intake tubes and MAF apart and make sure they have dried out. Maybe disconnect the battery while doing that, to clear any codes or memory, and then put it all back together and crank it up.
Do you have an OBD scanner available? Where exactly did you spray the Seafoam? I think the posts suggesting damaged/contaminated air flow sensor are on the right track.
Welp two steps forward one step back. See at the bottom.
First off, thank you to everyone for the help.
Second, I don’t know if its the fact that it’s 17 degrees, the fact I got 300k miles on the odometer, or a combo but I think I figured it out and made it worse.
I disconnected the MAF and it started right up. The MAF looks completely dry and untouched which is weird.
Yeah, I think it was the MAF.
I gotta disconnect to reset but I think you were right.
I don’t but it seems like it was the MAF.
In the process of the trouble shooting I broke some crap.
These hoses cracked (circled in yellow) and I snapped the anchor for this connector (circled in red). So I gotta find part numbers and hope the dealer has them in tomorrow.
Consequentially, I also found the coolant leak I have had. I didn’t even touch this part but when I got her cranked coolant started shooting everywhere. This T broke in two on the rear passenger side, I think it was barley holding together due to age. . At least I found the issue….
(Pic of tundra engine lc has more heater hoses)
Anyone know part numbers of the top of their head for any of these? I think I might see if I can find a metal replacement T for the coolant lines.
Thanks. Bought and switched!
Just to close this out. I bought some MAF cleaner from CRC and sprayed it out. I wiped out the intake hose, unhooked the battery, and waited about 30 min.
Buttoned her up and she started once and died. Tried again and was heavy with the gas and she runs like a top now.
Replaced the heater hose Tees with new metal ones from doorman and new hose clamps. Works great, no drips. No fear they will disintegrate like the old one. That was the most time consuming part. But was discovered only because of taking the MAF off. Not related to the MAF issue but serendipity none the less.
Thanks everyone.
Moral of the story, don’t spray crap on your MAF.
Just a heads up: It will always die immediately on first start after a battery disconnect. Can't remember what the reason is but its a feature, not a bug.
