Hi, looking for torsion bar & droop advice. My 99 LC is converted from AHC to OME 2". My (front) center hub to fender measurement is 51.5cm (20.27”) and full droop is 59.5cm (23.42”) so I have 8cm (3.15”) of droop which is currently limited by the shocks, I can get another 2cm (0.78") droop out of it with those disconnected. The rear is sitting at 55cm (21.65”). I think I should raise the front a little bit. Which (front) height do you recommend? Minimal droop is 6cm (2.36") correct? My torsion bar adjustment screws are currently almost maxed out, should I re-index the TB splines to get more lift / range on the adjustment? LC has a diff drop and stock UCA's. 32" tires. I'm also looking for recommended camber spec. Can provide more pics & info if required. Looking to really dial this thing in, any recommendations are welcome. Thanks!
