Retrofitting 2016 Headlights and Hood to a 2008/2009 LC 200 ?
Hi All
Been seeing in the used market 2008/2009 LC 200 retroffited with the 2016/2017 headlight versions, new hood and grill.
Anyone has done this modifications ?
Also among the 2008-2010 models have you seens any issues to be aware of ?
Here in Beirut, Lebanon most of the used LC 200 come with the 4.7 L V 8 i think this engine has the timing belt.....
I don't think it would be a good use of funds with all the things you would need to change. You could easily replace the halogens with an LED kit that would give you a big boost in performance, or you could retrofit a high quality set of OEM projectors into your existing housings for much, much less than that conversion.
If you’re going primarily for a lighting upgrade, you can go to the 2013-15 style. Massive improvement for me.
