Restoration of my Land Cruiser FJ62 1989 In Colombia, South America. Step by step
Colombia
Part 1, Greetings from Colombia.
I bought this FJ62 in late January this year, A japanese version with ambulance (Barn) doors model 1989. As you can see, car´s body was acceptable. However, my real intentions with the car were restoration to original condition of a standard version (G trim).
The specs of the car at the purchase time were:
Model: FJ62
Year: 1989
Engine: 3F
Trans: H55
Suspension: Lifted
Tires: Federal Couragia 35/12.5/R20
Now. I´ll gonna show you my own story of adventures and mishaps during the restoration process.
My car´s philosophy is "original is better", so I wasn´t happy at all with the aspect of the car; the monstruous tires and rims, the "ARB Wannabe" bumpers and the bicolor tone of the body, amongst other things, bothered me a lot. Nevertheless, I bought the car because the body was ok to restoration and the engine was aparently ok and no evidence of significant rust, the price wasn´t a bargain but was ok (About U$5000).
My goal was (still is) restore the car to this condition:
As soon I had the car in my hands the first step was to remove the big wheels. The ride was horrible and after a short drive my back was in pain and my ears buzzing because of the noise. I found some original steel rims (non splitted) from a FJ40/60s, the vendor offered me a combo incluiding the rims with a showcase tires Bridgestone 205/75/R16, that tire size is commonly used in the FJ40s here, hence I Bought them.
But...
The car still had the lifted suspension of the rims size 20, now the car looked even worst than before. I put some provisional emblems because the car doesn´t had it at the time of the purchase. With the new tires the ride improved a lot, but still I found it uncomfortable, the noise levels were still unbeareable also.
Next, I removed some leafs of the front and rear springs, the results:
Nothing noticeable, the car still looked lifted and unproportioned amongst the body and wheels size.
The exhaust pipe as you can see in the picture above was modificated for the previous owner in order to make room to the size 20 wheels, The modificated pipe was one of the main culprits of the unbearable car noise.
On the other hand, the fuel comsuption was awful and the engine had jerkings during idle, lack of power was notorious.
The previous owner had the car in a small town in the mountains about 8600ft ASL. I live at 3900ft ASL, so a tune up and a carburetor inspection was mandatory. The gaskets of the carburetor was broken and the smell to gasoline when the hood was open were terrible. The sparking plugs were burned and covered with carbon, I changed and fix the necessary.
The ignition also was a pain in the neck, it needed to pump the gas a lot of times in order to start the car, battery was in poor condition and was replaced but still the ignition had problems. Finally we found the answer: the solenoid in the starter was fried. it was rebuilded and the ignition finally was ok.
Next post: More problemas on the way
Part 2. The repair shop.
New exhaust pipe and orientation, the silencer was in good shape, so I Iet it in use.
Front axle was completely restored
Part 4. The repair shop.
Drive shaft, replaced brand new. Pictures of the old parts in poor shape
The gear box and transfer case.
Everything was in poor condition: gears, shafts, synchronizers, bearings, selector rods and velocimeter gear were damaged. Everything was replaced. The gear box and transfer case was restored in a 90%. Only the external case and some gears are still in use.
Wear in a synchronizer:
The speedometer gear:
Note the wear in the fifth gear
Part 5. The repair shop.
The body works 1.
No rust at all. However, the bonnet was in poor conditions and needs to be replaced
Part 7. The repair shop.
The body works 3.
This rear license plate will be transplanted from a 1990 FJ80 with ambulance doors:
Primer coating, Done:
Paint selection:
Body: 040 Super White
Bumpers: 1G3 Magnetic Grey
Rims: 1E9 Mica Grey
Paint test, Super White 040 on the roof:
Painted with the white base
Great photos showing your progress, and nice restoration efforts. It will look sharp when finished.
The "new" donor bonnet
Now, the bonnet is almost ready to be installed
The rims...
First try. Code 153 Warm Grey Metal... Very unsatisfied with the results
And now Code LE, Gun Metal
Gun Metal is the winner
Time to start the works in the interior
The actual dashbard was in bad conditions with some faux leather cover and with great signs of wear. Most par of controls and indicators not working (only Tachometer, Oil pressure and Fuel gauge)
As you can see the dashboard is a pile of garbage. It will be replaced
