Thanks Tom (
@lostmarbles)! Family issues are working out.
Regarding my FSM: I ordered it from Helm. It's the only Toyota FSM I've seen, so I thought it was the correct (1978) FSM. There is no real vehicle year on it - I assumed it was 1978, that's what I paid for. The only dates I can find are inside the back cover:
At any rate, I converted your mm measurements to fractions of inches and re-checked everything. It was all within hundredths of inches of your measurements.
The engagement point didn't change (last half inch (12-13mm) of pedal). Again, I'm not unhappy with where it engages... Just want to be sure I'm not inadvertently riding the clutch.
I went back and changed the slave rod to the approximate length shown in Mike's (@78fj40mg) picture. Same result.
I went back and adjusted the m/c rod to allow 1.5" of free play (per
@pb4ugo ). same result.
I went back and shortened the slave rod even more and
I am quite satisfied with the results - it engages just below 1" of top of pedal.
It's possible this was simply an exercise in futility - it's possible it was engaging where Toyota intended....
Regardless, I am now sure I'm not inadvertently riding the clutch all the time.
Thanks everyone for the insights you offered - I really appreciate it!!
