I'm replacing the outer tie rod ends and tie rod boots. Cannot get the tie rod to separate from the knuckle. Soaked the joint in PB Blaster. I tried a pickle fork, but I guess it isn't big enough. Also tried smacking the knuckle with a mini sledge to break it loose. No luck.
In the FSM (page SA-20) it shows the whole hub disassembled to get the brake rotor and dust shield out of the way in order to get a puller on the tie rod end. Is that really necessary? Doesn't look like there is much room there to get a puller in otherwise. Maybe detach the steering knuckle by removing the two bolts holding it to the hub and then putting a puller on that?
Also, what puller are people using? The one I have used on other cars isn't big enough.
Thanks.
R.
Thanks.
R.
