Replacing Tie Rod Ends
I do not believe Sankei 555 to be the same as Toyota OE tie rods. If the same price, I'd go Toyota.
We'll, I didn't write the purchase order for Toyota or bolt the parts to the the trucks at the factory, so I do not have first hand knowledge, but everything I've ever read about 100s has said that Sankei Japan is the OEM for the tire rod ends.
@cruiseroutfit sells both 555 and OEM outer TRE's, perhaps Kurt can chime in. A picture of the two side by side would be even greater =)
Sure. I'll post some side by sides tomorrow
Just pulled a set for you :D
We do have pictures on our website steering parts:
Cruiser Outfitters
(We stock OE ends, aftermarket Japanese (555) ends as well as complete kits)
Keep in mind there are two lengths of ends on the 100/470 (98-02 & 03-07 and they need to match the length of the inner end. All of our sets are of course matched :D
(These kits DO include the OEM jam nuts as well)
Loose Ends:
100 Series (1/1998-7/2002 IFS Models) Individual Ends
RH Outer Tie Rod End - Part# TRE4669195 - $37.50/each
RH Outer Tie Rod End - Part# TRE4669195OEM - $72.50/each (OEM Toyota)
LH Outer Tie Rod End - Part# TRE4769100 - $37.50/each
LH Outer Tie Rod End - Part# TRE4769100OEM - $72.50/each (OEM Toyota)
LH/RH Inner Steering Rack End - Part# TRE0369015 - $62.50/each
100 Series (8/2002-2007 Models) Individual Ends
RH Outer Tie Rod End - Part# TRE4669205 - $37.50/each
LH Outer Tie Rod End - Part# TRE4769115 - $37.50/each
LH/RH Inner Steering Rack End - Part# TRE0369025 - $62.50/each
Complete Kits:
100 Series Tie Rod End Kit - $187.50 (Now in Stock!)
Japanese 555 Brand - Made in Japan
Complete 4 piece kit w/OEM Toyota Jam Nuts
Fits 1/98-7/2002 IFS 100 Series Land Cruiser & Lexus LX470
Part# TRE100ETRE
Fits 8/2002-2007 IFS 100 Series Land Cruiser & Lexus LX470
Part# TRE100LTRE
Well, there is the difference. The 555's look sand-cast, are the OEMs forged? They don't have the same rough finish and casting seam as the 555s. Or are they just a slightly cleaner casting?
They are both absolutely forged, the Toyota unit just has a higher level of finish work and paint. Fwiw we've sold 10,000+ 555 TRE's and have had exemplary service with them. I've got a customer running King of the Hammers on them next week :cool:
Already have them on mine, but Florida trails aren't quite King of the Hammers. :-) Thanks for the info!
Can anyone chime in on proper placement of the dust boot ? Just got back my rig from Toyota and it appears the boot isn't clamped all the way tight so it moves.
For example one of the clamps ( new tie rods have these plastic adjustable clamps ) wasn't that tight and with the wheel fully turned it compressed the boot and it doesn't spring back.
I assume the boot should be pulled all the way over the threads and secured near the adjustment nut but I'm not sure , maybe it needs to be kept kind of loose to be able to compress and what not?
