It's a lot of reading....probably just start at page 5 or so....as most helpful information is later in the thread.
An OTRAMM video (step by step) would be awesome. Maybe someday. His videos are always so clear and well done.
How To: Replace your own steering rack
Now up to $55, but still available while most are only selling it w/ the high pressure line: Sunsong North America 3402991 Power Steering Return Hose | eBay This delivered quickly and fit reasonably well. The threaded fastener is a little different than factory. I took some pictures that I...forum.ih8mud.com
Are you running AHC? If yes, I made some posts about the type of ratchet that worked well in the cramped space to access the left side motor mount.
Motor Mounts - How long should I expect them to last?
Did you replace 1236150121 and 1237150081? Anything special to changing them out? Just support the motor with a padded jack under the oil pan? Pro tip- only disconnect and replace one side at a time. Keep an eye on fan blade clearance at shroud as you raise motor.
