Ok, so I actually have a 60, not a 40. But since it has the non USA points dizzy, which I believe is the same setup as a '76 FJ40, I thought I might have better luck here. I'm having troubles with my ignition which I have not had much luck diagnosing. In an effort to get my truck running in time for our TLCA chapter event this weekend I thought it might be easier to swap in electronic ignition. We have the complete dizzy/ignition setup from a smogged 60 (still installed on the truck) that I could borrow. What I'm wondering is what modifications would I need to make to the wiring harness and vac lines to get it to work?
So if any of you have swapped out the points ignition on your 40 to a 60 electronic ignition and have a list of the necessary modifications it would be appreciated very much.
