does anyone have know if there is a mod kit out there to simplify adding component speakers for the front with a crossover?
i'm reluctant to start hacking wires..
it's the tweeter i'm worried about f&ckin up..Yes, Metra makes speaker cable adapters for both the front and rear speakers. Plug in the adapter and hook it up to the crossover.
thx @zapatius i just don't want to mess up any of the factory wiring that eventually goes to the rears.You're replacing it with an aftermarket one, correct? And you're wanting to run the aftermarket crossover? You will want a surface mount tweeter to go on the bracket it looks like. You won't be screwing it up, you can run speaker wire directly to it from the crossover without using the factory wire. I don't know specifically on the tweeter if there's an adapter that works for the factory wire and an aftermarket crossover.
Try this thread:
speaker install writeup
Thought I'd post my speaker install that I just did with the help of the search function and compile what I found in several threads that may help others. Here is the link to the door panel removal thread that was very helpful...forum.ih8mud.com
Also, Crutchfield has a few pictures of the tweeter install on their "My Vehicle" page for a 2006 LC.
You use the lower connector adapter to not hack it off and connect the bare wire ends to the Xover. Then use your own wire to connect to the woofer and tweeter of your aftermarket speakers.
I'd be very careful of running an aftermarket woofer and stock tweeter on the factory amp. The chance for spectral impedence mismatch is very very high and not great for performance or the amp.
