Replacement Plugs for FZJ (1 Viewer)
Nashville, Tennessee
What replacement plugs do you recommend on a 1996 Cruiser?
Better luck with any particular kind?
Thanks in advance.
Nippondenso K16R-U
Toyota part number 90919-01176
You can't go wrong there. Suggested list price $1.97 each.
Regards, Dan :beer:
Cruiserdan is spot on...Only put back OEM
ND K16R-U
NGK BKR5EYA
Either will work. Get anything else and you will be sorry.
Make sure the gap it set at 0.8mm or 0.031in...
I just put the Bosch Platinum plugs in my 96 Cruiser
Made sure they were gapped properly and they have been fine. $1.99 each
I went with NGK Iridium Spark Plugs. Very$$ I have no complaint with them of any NGK plug, Execpt for use in my 5hp Mercury outboard. The only plug that could get it to run smooth was the Split Fire. They don't do anything in my Toyota's but they do some thing to small engines that the others can't. I have tried dumping all kinds of oil gas and oil mixes into the 4cycle BS lawn engine and it doesn't foul out.
kurt
NGK Iridium Spark Plugs are excellent plugs! They are made from a very hard metal. And wiill last longer than Platnuims.They are rated to last to 90K. Give better throttle response and resist fouling. Require less voltage to spark and deliver increased burn efficiency, spark at leaner air/fuel mixture, produce better gas mileage and higher horsepower. Awesome plug!!
