replacement brake pads for 1995 HZJ75 series ute
I am trying to source out brake pads and brake pad part #'s for my 1995 landcruiser
It has front and rear disc brakes
attached is a picture of front unit.
I have 0446560020 as the toyota part # for a HDJ81, but I was hoping for a napa cross # or lordco cross #?? and I am also unsure if I have the same rotors/pads as the HDJ81
I do understand that OEM are far superior. I just want to explore my options incase I cant wait on toyota shipping!
Aloha
I just put front pads on my 01/95 HZJ75 and the 80 series aftermarket pads (Carquest) are very close. I had to grind down a tab to make the pads fit. No biggie. They work great.
Carquest sells Carquest. Carquest is like NAPA and is a parts retailer throughout North America.
I am sure the NAPA 80 series front brake pads are the same as Carquest.
Any more info / pics of the coils inthe front end
I picked up a set of 1995 80 series pads from my local shop(lordco) and they fit perfect, the front pads needed 1/8th " grinded in order to sit properly.
front pads were $110, rear were $90
replaced the rubber top brake lines while I was at it (visable crack )
If you can fit the 80 series (04465-60020) pads, you should be able to fit the larger pad area 100 series brake pads (without the shims): 04465-60220. This would be a good braking upgrade considering the latter has a larger pad surface area.
