My alternator died recently and I replaced it with a 100-amp version. Everything runs fine, turns over perfectly. But the 15-amp fuse to the gauge cluster keeps blowing as soon as I start the truck.
1998 100-series
Thoughts?
follow-up question: I did re-charge the battery with a plug-in wall charger before putting it back in. Is it possible this might have something to do with the problem? If so, how can I test for it?
updates:
The fuse blows out as soon as the key is turned to the ACC position.
The battery tests at 12.47v at the terminals
No other fuses in the cab or in the engine bay are blowing, just the 15A that runs to the dash gauges
The only wiring that was touched during the install of the new alternator was the ground on the alternator and the wiring harness that goes into the alternator. Could either of these be the failure point?
1998 100-series
Thoughts?
updates:
