1994 80 Series. Started to change belts. Bolt head tensioning the adjustment rod is rounded so I'll have to remove the alternator to get it out. Looks like adjustment bracket has one bolt on the block above the idler pulley. I assume there's one or more bolts at the other end.
What do I need to remove to get out the alternator with the bracket attached? Will it come out without removing the battery tray? Things seem pretty tight around there, even for removing the alternator without the adjustment bracket attached. I'm assuming it's actually possible to disconnect the adjustment bracket from the engine with the alternator attached. Perhaps this is not even possible.
Any hints welcomed.
Any hints welcomed.
