Good evening Mud,
I am looking for people who have removed their front sway bar entirely and opinions on the other hand of why one shouldn’t. I have read a few things here and there, but nothing concrete on decisions made. My reason for asking is, for about 4 years my frame mount has been broken off on the passenger side. I noticed it a couple years ago while doing some maintenance, but remembered back when it happened once found. While I’ve noticed no handling issues on or offroad, even at highway speeds, I also don’t know if I’ll be able to weld it back in.
Here is my use case. I daily drive my Cruiser about 20-25 miles round trip 5 days a week. Roughly 3-5 times a year it makes trips to our cabin in Northern Michigan, which sees about 1-2 hours of highway handling on the 4 hour trip one way. Once there we wheel on forest service roads and some off-camber two track trails - nothing super heavy, but up to 120 miles of trail per trip. Each trip is around 400-500 miles.
As for aftermarket add ons I have a steel front bumper, FOX shocks front and rear, welded in tube rockers, small fly fishing load out with attic rack in rear, a custom rear tire swing out, 305/55/20 KO2 with Tundra 20’s, and some roof mounted recovery tools.
I am doing a 300k front end rebuild including new UCA’s, new lower ball joints, new LCA bushings, new outer tie rod ends, and new wheel bearings with all the hub fixings. While doing this, I am installing a set of 30mm Nolathane rear spacers and cranking my torsion bars a bit to accommodate.
While doing all of this I am looking to nix the sway bar while I’m at it. My thought is the sway bar seems somewhat redundant in an IFS with this much front end weight. If I get in there and figure out I can weld it back in easily, I might do it and put new links on. However, I’m just planning on it being removed.
Am I crazy?
Am I crazy?
