Agreed. Once you get going it’s not that complicated of a process. When I did mine the Haynes manual was actually the most helpful. And there won’t be a better time to clean and refoam your ducting. I actually put a new dash pad and glove box in at the same time.Honestly it’s a pretty simple affair. Just label bag the screws and bolts as you take things apart. There are no surprises. I have a ton of pictures of mine as it came apart so I can probably help if you get stuck on reassembly. And it’s a worthwhile project. I would recommend getting some 1/4” grey foam before starting so you can redo the flaps in the heater and A/C boxes. When I get a minute I’ll post up a few pics of the process.
Long story but while trying to track down where I was losing coolant, I found that the previous owner had screwed a 12V plug into to side of the core. They sealed up the two holes and rebuilt the core with more robust fins.Thank you both! I'm starting grad school in two weeks, so my window of opportunity may have come and gone. I limped through last winter with good heat to the cab but only warmish heat on the windshield. I may push it to my next term break, but now at least I know more about what to expect. Question; what sort of service or repairs did the shop handle for your heater core? I think most of my issues are due to bits of foam (or possibly dead mice) keeping the various sliders from moving as they should.
