I did it, knuckle overhaul. I was scared but I looked up info on the web,( check out coolerman's web site it's got a ton of great stuff) read my shop manual 10 times or more and in the end it wasn't so bad. Dirty and greasy but not so bad. Driver side tear down and rebuild with a kit from Four wheel auto one day not major issues. Second passenger side not so good I destroyed one of the studs for the top bearing for the knuckle, trying to remove the infamous cone washers. Most of the washers were easy to take out with a tapered punch wacked into the crack and they popper right out. Two cone washers on one side were stuck to the studs so bad that 4 hours of work were not enough to free them. The end result was that I cut the stud, drilled out the stud to empty the cone washer, pulled the cone washer and pulled what was left of the stud with the knuckle in a vise. Then I had a beer.
So................. it's ready to reassemble and I know that one day I will have to do this job again for what ever reason, so I want to replace the studs nuts with bolts. What is the reason for putting studs with a hex nut in the first place ? I get the reasoning for the cone washers, but they are so much easier to take out when the studs come out with the nut. ( When they are all rusted and gummed up like mine) What info am I missing that would prevent me from replacing these studs with regular bolts of the same grade ? Any opinions or knowledge would be greatly appreciated.
