The radio sucks ass to begin with and without the mast the reception was horrible. The powered antenna I had installed across the top of the windshield was no help what so ever.
Before I removed my factory RH fender I made a template, just in case I wanted to re install my antenna on the passenger side. So I taped up the drivers fender and took out the template and outlined the hole with a Sharpie and said a prayer. I found center on the lower circle and top and then drilled the holes using a step drill bit. Then took out the file and went at it.
