Rekeying driver door cylinder
Charlotte
Hello,
My drivers door handle was replaced by the PO and they apparently did not swap over the original lock cylinder. Is it possible to have the cylinder re-pinned to work with my original key?
A trained/experienced real locksmith that works on car door locks should be able to do it.
IME some of the national chains hire guys to drive around in a van who only know how to break into locked vehicles or a house doorlock, so you'll want to call a few shops to find a real locksmith and ask them if they can do it. A smaller independant shop is probably your best bet.
Or, do it yourself:
@Delta VS specializes in the 80 SERIES locks
i ONLY code cust SST machine 80 series ket as of now
i CAN tackle it if he can't for some reason ?
he is a SOLID SUPPORTING VENDOR as well
matt
Thanks, @ToyotaMatt, I'm just looking for the easiest way to get my driver door lock working. @Delta VS, what is your recommendation for this situation? The key will go into the driver side tumbler, so I'm assuming it's a proper LX cylinder or else the "laser key" wouldn't even go in, right?
Just had eye surgery, please excuse typos. You have LX I take it? Your local locksmith should be able to deal with that for you, otherwise if you send me your key and the cylinder I can do it for you.
if Mr Delta is unable to assist due to his eye healing
PM me ill pick up the need at assist here with his OK , of course
i can do the Ignitions , door locks front
NO LEXUS high security ........... mumbo jumbo ............fyi
