Reining in an oil burning engine? (1 Viewer)
gray rider
Cedar Mtn, NC
I have no noticeable oil leaks. Currently burning a quart of 0w20 approximately every 1500 miles.
Can oil consumption be reduced by changing from 0w20 to 10w30?
Is the oil substitution ok in a 200 series engine?
Can a faulty PVC valve cause excessive oil burning?
Thanks.
Sounds like a great question on the plugs....unfortunately the miles on the engine are a mystery. Here is the tread regarding that:
*Thread
PCV valve has been a source of oil consumption multiple times on this board. Genuine Toyota part is less than $10 last time I checked, might as well throw one in. And I’d recommend using that over parts-store.
Also it’s plastic, don’t over-tighten the new one.
Beyond that, you can absolutely switch out to a thicker oil without harm to the engine, it is actually recommended in large parts of the world with this engine. Many of us run 5w-30 and even some 0w-30 with reports of quieter valve train.
Good info. I'm on it....
+1 on the pcv valve needing to be changed. As beaten to death before, the 3ur-fe is usually super easy on oil.
On the oil forum, people have had some luck after a couple runs of Valvoline restore and protect in reducing consumption. This hasn’t worked for everyone, but has worked for enough people imo to say give it a shot. Just be ready to change your filter early in the oil life cycle (assuming there’s a lot of carbon build up/sludge this stuff will be cleaning).
I’m not saying the valvoline will definitely cure your ills, but imo it couldn’t hurt. And it also comes in 5w30. HTH
@gasman: Is the "Oil Forum" Bob is the oil guy?
Is this the link?:
Is this the link?:
That’s a good start. Just be ready for a deep dive into a lot of good info, but intermittent bullsh*t and voodoo.
VRP is good oil. IMHO it’s where I’d start (pcv first) to (hopefully) rein in your neglected engine burning oil.
