[Revised]
Turns out the design location for the REDARC Manager 30 is pretty much right next to the aux battery, with the sensor assembly literally on top of the positive terminal. And the 30 is not to be mounted under the hood. Well, damned if I'm gonna park a corrosive-offgassing, 5000A short, 80-pound missile of a battery in the cabin. Just not gonna happen.
Which means the 30 goes in the cab, and the aux battery stays behind the PS headlights.
Now, according to REDARC (if I'm understanding the correctly), the M30's sensor is designed to monitor "true" battery temp and voltage (and current)--and if I mount the M30 itself far from the battery, it will (by implication) not read 'true.' And the shunt cannot be extended.
So, for all the electrical engineers out there (licensed and otherwise): is there a fix for this--a way to get true battery temp / voltage / current readings to a Manager 30 that's mounted, say, 7-15 feet from the battery?
Thanks for any help!
Manual:
Manual:
