Half an inch in Freedom UnitsMy digital caliper read 12.2mm thick
Metric for the winHalf an inch in Freedom Units
I think I have one that I took off when installing an ARB bumper. If you are still looking, I'll check to see if I still have it. It's from an 2002 LX470 but should be the same.Resurfacing this thread. I’m still trying to source one of these “raptor claw” OE tow hooks, in case anyone has one available. They’re fairly rare apparently and like >$200 new.
I’m 90% sure that aftermarket recovery points won’t work with a stock bumper, but I’m open to convincing otherwise. Here’s why: in a nose-down scenario you’re likely pulling up a little, which will slice through that bumper like dental floss through tofu.
So one more bump for a used one out there in ‘Mudland, else I’ll look at custom fabrication. Already reached out to Jason at @TRAIL TAILOR.
This one came off of my passenger side, front.So I scored some OE recovery hooks locally, and I’m trying to figure out the design of the big one:
1. I believe this is the passenger (USDM) side front. See how the hook part is angled? What’s up with that? Is the assumption that a recovery line will be angled towards the centerline of the vehicle?
2. What was originally on the driver side? The threaded bolt holes are identical. I have a second one of these large hooks, but is that angle passenger side-specific?
I disagree, there are 4 separate closed loop attachements that are used for securing the truck during transportation. Those aren't meant for dynamic loads of pulling on for recovery.Those hooks were designed for anchoring the car in transport, not recovery.
That being said - will you break them if you pull on them? Probably not
OE bumper is sacrificial.
