I guess that the title says it all. I have rebuilt the engine and have set it up to bench run.
I get the correct idle pressure , but it never goes up to the 3+ bar when the revs are increased.Yes, I don't like to rev it too high without a load, but it's still not getting much above 1.5 bar.
I am using a mechanical guage which flicks up quite nicely even with my oilcan providing pressure.
Tested with the turbo and alternator and injection pump feeds blocked and still the same.
It has a new oil pressure regulator piston and spring fitted, and both pump rotors were replaced with new.
The filter is not Toyota, but the Fram equivalent and I have not changed this out yet.
When rebuilding the pump, I made sure that the two rotors were lined up (two marks on the rotors) , but do not recall that they had to be in any particular rotational position, did I get this wrong??
Any clues please folks???
G
G
