I became owner of a fj60 recently, in very good shape except for the roof rust. Most of the drip rail is rusted, especially rear corners. the outer shell of the roof has its share of rust going up about as high as 3 inches above the rail, almost around the whole truck. drivers A pillar rusted pretty bad too.
I decided to get started on the rear passenger corner. I removed the rusted outer roof section by cutting it out with a cutoff wheel above the rust and down right through the drip rail (being careful not to cut the inner shell of the roof) and peeling the metal down to reveal the spot welds on the drip rails, drilled out the spot welds and with a few tugs it came right off. The inner roof so far appears to have very little surface rust, no rot at all and very solid, very nice surprise to see. There are some holes from drywall screws from a previous repair attempt, but a solid foundation to build on I would say.
Now I need some drip rail so 3/4" 16 gauge square tubing makes some very similar to factory with some plasma cutting and opening up a bend on the tubing on a press or vise.
Seriously, I am just glad that people take the time to post and we all learn something. Awesome community
