Thank you. I have read in multiple different sites that u typically reuse the stock shims. But I've been searching for a while and just connot seem to find an answer to my completely ridiculous question lol. But here it goes, I pulled the passanger side knuckle to go thru it, and I noticed there is only one shim on the top side of the knuckle. And one on the bottom cap. Is there supposed to be more?
I'm going to put this delicately....
The shims that should be on a knuckle (both top and bottom) are determined through the use of an SST. There are multiple threads about using the Knuckle Centering Tool SST, and about rebuilding the knuckles in general. There are also detailed instructions in the FSM.
If you have not taken the time to understand the knuckle rebuild, or how to do it through the FSM, you have no choice but to assume that whomever had it apart before you did it correctly and thus that the shims are correct for your axle and knuckle. You should therefor duplicate what you take apart. Sometimes it's one shim, sometimes its more. The shims vary in thickness, so make sure you mic out the removed shim (since I'm guessing you damaged it a bit removing everything), and match it to a new shim of the same thickness. Pay close attention when you reassemble it to make sure that the pre-loads are correct, because if they aren't--your shims aren't right. And if they aren't correct in your case, then it's time to start looking for someone with an SST you can borrow, or buy one (they are about $150 IIRC, and take a couple weeks or months from Toyota OPC).
[quote\]Also, how do I get the bearing off of the bottom cap on the knuckle? I looked thru my chiltons manual, and it doesn't say how to remove it. Am I missing something here? Thanks for all the help guys[/QUOTE]
The same way you remove any bearing that is stuck on a spindle. The bearing itself isn't important, because if it's stuck on there it was likely no good anyway. You can use a bearing separator (what I do), but some people cut a small slit in the bearing itself (be REAL careful not to get into the bottom cap spindle) to relieve the clamping pressure, and others heat the bearing until it slides off the cap spindle. Some combination of those may be necessary
Good luck!
Dan
