Rear window
PNW
Trying to confirm what I need for a rear window issue I have.
The passenger rear window has always been a little slow and sometimes needed a little help going up. Today that ended and it would not go up at all, although it would go down when pressed. Pulled the door panel, no obstruction..ultimately pulled the other doors switch, hooked it up and it worked flawlessly. It also does not work from the driver controls...
So I am assuming this is an isolated switch problem? Or do I chase a wiring issue on this switch since DOWN seemed to work, not up.
Thanks for your help,
Mike
