Rear Window Motor
Discussion in 'FJ55 Iron Pig Preservation Society' started by 75PIG, Oct 23, 2005.
  1. 75PIG
    75PIG
    357
    6
    Jul 12, 2005
    I think I am getting moisture in the back window -- rubber strip is shot.
    The rear window sticks -- If I push it a bit it will go down but have to keep working it up and down (electronic) to get it all the way down or up. Last week I was lucky to get it down. Any solutions or advice as to "where" to start?
    Thanks
    75 PIG
    See also 75PIG update in the classified --- posted it in wrong location. Should I move it -- I am looking for some carb parts too?
  2. snailwagon
    snailwagon
    1,042
    4
    Jun 11, 2004
    high desert, ca
    On mine, the rear window will stick from a little bind in the channel. Since my window runner is shot, I just grease it up from time to time. I
  3. 75PIG
    75PIG
    357
    6
    Jul 12, 2005
    Thanks Snailwagon
    What do you use for grease. Will try it --- annoying bugger.
    Added some pics -- rubber is getting hard but channel seems to be clear --- the lower rubber is deteriorated so was leaning towards something else mechanical --- maybe not, will try the grease.
    Anybody else want to chime in with their experience with this?
    Thanks
  4. RHINO
    RHINO
    3,769
    12
    Dec 23, 2003
    Payson, AZ
    my window used to be real slow, real real slow. sometimes while rolling up it would trip the breaker and i would have to wait a little bit before i could finish rolling it up. i dont know exactly what it was or to which end was the fix, but i pretty much took it all apart, cleaned it, greased it and put it all back together to have it working pretty smooth and quick now.
  5. Yotahilux
    Yotahilux
    196
    Apr 29, 2005
    VA
    My rear window acted the same as rhino's then all of a sudden, it stopped all together. Took it apart and foung that the nylon gear on the motor was busted. Ordered a new one from toyota and havent had an issue yet.
    Pig Head posted a good part number for the gear a while back.
    Chuck
  6. 75PIG
    75PIG
    357
    6
    Jul 12, 2005
    Rhino - Snailwagon-Yotahilux
    Thanks for the starting path -- appreciated
    Check out my "other" post on 55 classifieds -- looking for some stuff to get it on the road.
    thanks again
  7. BushBoy
    BushBoy
    162
    Feb 26, 2004
    Darwin, Australia.
    i had a rather odd problem with my rear window, it would go up really quickly yet take ages to go down. i pulled it apart and realised the helper springs were around the wrong way. problem fixed, cleaned and greased also, and it now works fine. now i just need a new key switch, as mine is fubar.
  8. KliersLC
    KliersLC
    3,540
    325
    Oct 14, 2004
    Virginia Beach, VA
    I found that it sticks when the window frame on the bottom contacts the motor inside. On mine this is due to a loose tailgate--ie, if I push on the gate and have someone operate the switch it works fine. BTW, anybody know if there is an adjustment on the tailgate latch?
    Good Luck,
    Dan
  9. snailwagon
    snailwagon
    1,042
    4
    Jun 11, 2004
    high desert, ca
    For lube, I used something called white lightning. It is a paraffin based lube mixed in petroleum distillates, meant for bicycles. Doesn't dissolve the rubber. Any thing you can squirt in the channel will work, but if your rubber is in good shape, don't ruin it with chemicals. Mine goes down just fine, but every now and then getting the window up takes a little tug part way up. Lube it and forget it. A while ago my window would barely go up and down, then a month later my battery died. With the new battery, the window moved quick.
  10. 75PIG
    75PIG
    357
    6
    Jul 12, 2005
    White lighntning! I can remember that. I will eventually prbably clean everything up since I haven't had the back panel off yet.
    Thanks again for all of the input.
    75PIG
