This weekend i hooked up a rear view camera and tapped the DS kick panel. On a 2001 LC there is a RED/BLUE cable on a large square connector there. When i tested the camera worked as it should. Put shifter in reveres and camera came on.
Unfortunately i put everything back too soon.
I noticed that when the reverse cable is connected to the stereo nothing else works. When i disconnect the reverse cable all functions work but i have to manually turn on the camera when the shifter is in reverse.
Not sure if i tapped the right wire or if i should run cable to the rear reverse light and tap there. I ran out of cable so i could not tap the reverse light for testing. I also looked at the ECU but there is no RED/BLUE cable to tap.
Any ideas?
Any ideas?
