Rear trim piece fell off (1 Viewer)
Nevada
Is there a part number for the rear silver piece just above the license plate?
Or a source where I can buy just that missing piece?
Every time I search for anything "LX470" on ebay there are a hundred different sellers for those that pop up.
Thanks. I found out its called a Garnish and apparently my part number is 76812-60010.
I have used partsouq before but shipping on these is kinda high. I will probably take my chances on ebay.
Just make sure you remove all the old double sided tape before installing the new piece. If you half ass it, it won’t bond well and will not sit flush and fall off shortly. Don’t use any metal objects to scrape away the old glue. I use Rapid Remover at work for stuff like this. It’s paint safe and has a very long work time (doesn’t flash quickly like other solvents). You basically spray it on liberally to soak the adhesive and after a few minutes (5-10) minutes take a plastic card or plastic razor blade and scrape off a thin layer off it. Then repeat. You have to shave it off layer by layer. Trying to remove the entire thing won’t work trust me.
I did this to my 80 series a few years ago. Such a pain in the ass. I spent hours on it because I didn’t want to damage the paint but the end result speaks for its self. Good luck
