Rear Shock Advice
Need some help from the collective minds. My rear shock (OME) is loose and rattling on bumps. I have the right 22MM wrench to tighten the shock; however, the shaft spins when I try to tighten it. I used some vise grips with rubber wrapped around the shaft/piston, but I still can’t get the nut to tighten.
Any advice for me? The nut is currently soaking in PB Blaster to help loosen it up.
Thanks!
