Rear Pinion Slow Leak
Lakehouse
This pic was from today after this portion of my project has been sitting for over a year without moving. The dust has revealed a leak.
Is this due to a bad pinion seal? How many :banana: job is this?
What does MUD suggest here? It does not seem to be enough to even leave a drop in a year, but just spreads out.
I am learning on this project and have rebuilt my engine, but for some reason this seems daunting to me.
What to do here?
i just replaced my rear pinion seal. the seal was like $9 from the toyota dealership, you pull off that driveshaft flange and you will see the seal. pry it out its kind of a pain in the butt it doesn't matter if you destroy it tho since your replacing it. to install the new one i got my water pump pulley (had it laying around) put it on top of the seal and laid a piece of wood across and hit the wood and it put it in perfectly. make sure to lube up the new pinion seal well especially the inside theres a "spring" in there you dont want to fall out (its not a real spring i was told so dont freak out like i did)
