rear leaf spring spacers (1 Viewer)
Louisiana
I'm in the process of installing a Dobinson's lift on my 82 FJ60 . On the rear springs , do I remove both rubber spacers (top and bottom) and put the leaf spring center pin spacer on top of the spring ? Or do I need 2 spacers per side ? Top and bottom of spring ? I have read some discussions on this recently but just want to make sure I understand.
No rubber spacers, no metal channels. You will need two of the Old Man Emu part number CBS01. The leaf spring center pins are ~1/2” and the hole they fit into on the axle side spring plate is ~1” - the CBS01 part is a small round spacer so the center pin isn’t shifting around in the larger hole.
