....and my truck is broken, too!!
There is a noise and binding that almost stops the truck at slow speeds. The noise is a popping sound and happens as the truck seems to strain and then release from a bind in the drive train. I thought it was the bearing that holds the drive shaft, but the situation is the same after replacement (needed to change it anyway..).
Is the rear end going out? Fluid level is about 1/2" below the fill bolt hole.
I had a friend walk along the side of the truck as I backed out of the driveway then pulled back in. He said it was definitely from the back of the truck...
Anyone have a stock 'chunk' to sell cheap?
Thanks!
Dave
Thanks!
Dave
