You're thinking backwards. The crush sleeve is there to maintain proper pinion bearing preload, and since by the time the pinion seal is leaking the bearings have worn in, it's a good idea to tighten them up anyway. The only thing that will let the pinion ride into the carrier (short of blown bearings) is loose pinion bearings either from getting worn out, or from the nut backing off.
I usually reuse the pinion nut and turn it past where it was staked before and check for up and down to side to side play in the pinion till it's all gone. It's tough to check the preload with the diff in the truck though, but I make sure I can turn it easily by hand in that small free-play window before the pinion contacts the ring gear. If you tighten it up too much then it will bind up and harm the bearing in the long run.![]()
Yeah
This is completely FALSE.
if the pinion is way overtouqed (think extreme case) and the crushsleeve is collapsed even more it is going to pull the pinion away from the carrier.
The ONLY two ways a pinion head can hit the carrier is if the pinion nut backs off and lets the pinion shift inward or if the small pinion bearing fails/wears/crumbled and lets the pinion shift inward.
Yeah
You can't make it run shallow either, you can only over tighten the bearings which will cause premature failure, or under tighten them which will also cause premature failure. Under tightening can lead to the pinion hitting the carrier, but other than that you can not adjust pinion depth without disassembling the diff.
Yeah
Yup, good point. The crush sleeve maintains the bearing preload and has already been crushed, retorqueing the flange could crush it further and cause the pinion to run too deep into the carrier. Though I will admit ive done it and not had any problems yet. But with the exception of only a few bolts I never really pay attention to torque specs.
Nevermind, I was on a crack binder. Havent messed with diffs in a while, cant pull a pinion through the housing and shims.
But to the op....drop the fluid.
