Rear Door Grab Handle Broken - Fix Repair - with Toggle Nut $5 (1 Viewer)
Hornd
Toledo, OH
Supplies
Get 2 - 1/4-20 Drywall Toggles with Bolts (see pic), Vise, Hack Saw, Chainsaw File and Screwdriver that Matches Toggle Bolt, Alex Plus or Similar Silicone.
  • If your Pull Handle Has Not Pulled Off yet it will.
  • This method is Cheap & Maintains the OEM Look.
  • I used a Bench Vise to Hold the Handle Mounts while I sawed - Too hard to Saw and Hold at Same Time.
Top Tab - Saw (Hacksaw) or Break off if not Already Broken - Both Sides
Bottom Tab - Saw Half Way Off.
Using 3/8" Chainsaw File Make a Round Groove in Mount (see pic) to Fit Bolt
Fit 1/4 Toggle Nut with 2.5" 1/4-20 Bolt.
Push Toggle in Square Hole of Door and Tighten Bolts
Put a Dab of Silicone in Bolt Cover and put on.
10 Minute Task
**Use a Washer in Spring Loaded Hinge to Hold it open while you work.
Good save!
Mine won't fall off. Para-cord handles held on by threaded steel tabs now...
...But I was told it's a useless mod and there's nothing wrong with the OEM.
I was so close to getting Paracord but a tan one was hard to Find. That’s when I looked into this.
Supplies
10 Minute Task
**Use a Washer in Spring Loaded Hinge to Hold it open while you work.View attachment 3304490
Nice repair
Ohana Rig Supply- cost a bit more then a drywall toggle though..
Nice! but $65 plus Shipping is a Tank of Gas +
Yea true.. They're nicer then a drywall toggle.. but, to each his own.. You build your rig to your specs friend.. have fun with it..
Tru dat. I used soft Jeep grab handles when they used to be like $10 for the pair on Amazon. Then got hardware from Home Depot.
Bartact TAOGHRPBR - Wrangler JK Rear Side Sound Bar Paracord Grab Handles (Pair) - Made in USA - Black/RED https://a.co/d/hdwDE6z
Supplies
10 Minute Task
Thx for the fix. Did it today. Great fix!
The Ohana handle is the paracord, metal plate, and drywall toggles. I've got one
I had no idea it used Drywall Toggles.
Paracord or Plastic both Work Fine.
