Hi experienced AHC mechanics,
I'm writing this out of desperation/frustration....
I'm trying to replacing a dead rear AHC shocker. But access to the top mount appears virtually impossible. The cap with the 2 x 12mm bolts: the rear most one is just possible to access (although of course it's rusted fast), however how do you access the forward one ? Is it actually necessary to remove the fuel tank to gain access (or lift the body off the chassis) ? or is there some weird trick I'm not seeing ? I've seen references to fixing a spanner and rotating the shocker body to loosen the 22mm main top nut, but not the cap bolts. Also other that have resorted to cutting holes in the body to gain access ?
See attached image for part diagram.
Any/all tips gratefully received,
/Pete
I'm trying to replacing a dead rear AHC shocker. But access to the top mount appears virtually impossible. The cap with the 2 x 12mm bolts: the rear most one is just possible to access (although of course it's rusted fast), however how do you access the forward one ? Is it actually necessary to remove the fuel tank to gain access (or lift the body off the chassis) ? or is there some weird trick I'm not seeing ? I've seen references to fixing a spanner and rotating the shocker body to loosen the 22mm main top nut, but not the cap bolts. Also other that have resorted to cutting holes in the body to gain access ?See attached image for part diagram.
/Pete
