Really Stupid Question...4WD Low
Discussion in '100-Series Cruisers' started by JMan5000, Apr 16, 2018 at 8:35 AM.
  1. uzj100
    uzj100
    6,292
    1,354
    Jun 18, 2003
    Raleigh, NC
    That is really strange. I have never seen a 2000 or newer auto lock the center diff when selecting 4 low. Post up a video of moving lever to low and the center diff light coming on, on the dash.
    I will see if I can find the Toyota/Lexus documents about this.
  2. 2002TLCyes
    2002TLCyes
    79
    13
    Jan 18, 2018
    NY
    Same here, my 02 does NOT lock center diff when in 4LOW
  3. Das Shtig
    Das Shtig
    15
    1
    Oct 12, 2016
    Winter Park, FL
    01 LX470 my Center Diff does not auto lock when LO is engaged.
  4. hj 60
    hj 60 JT1W0HJ6000960839
    2,384
    729
    Aug 1, 2012
    Netherlands Hengevelde
    What happened to the friend, can he walk already?
  5. FastCarGuy
    FastCarGuy SILVER Star
    623
    53
    Mar 13, 2008
    Phoenix, Az
    My apologies! :redface: You guys are all correct! :redface: Don't know what I was thinking but sure thought my ctr. diff locked when I drove off road and used low range a month ago. I just drove across a dirt lot and engaged low range and turned sharply and it did not bind.
    TLCPNW likes this.
  6. uzj100
    uzj100
    6,292
    1,354
    Jun 18, 2003
    Raleigh, NC
    No worries my man.
    And when u lock the center diff, the dash light indicator should come on.
  7. uzj100
    uzj100
    6,292
    1,354
    Jun 18, 2003
    Raleigh, NC
    No worries my man.
  8. budlightpup
    budlightpup
    10
    8
    Feb 4, 2018
    Virginia Beach Va.
    I love it when people post stupid questions. I learn from them every time. In the future I will be posting lots of dumb questions because I just don't Know this rig, Please be patient with me.
  9. YvesNL
    YvesNL
    111
    160
    May 30, 2017
    Netherlands
    My Januari 2003 HDJ100 automatically engages the centre diff lock when switching to Low Range. Dutch/European Cruiser.
  10. BILT4ME
    BILT4ME
    4,708
    Media:
    3
    Albums:
    2
    4,966
    Nov 9, 2012
    Olathe, KS, USA
    There is not a "mechanism" that prevents it, it's shaft rotation.
    Since this is an automatic transmission, the transmission output shaft will continue to try to rotate as long as it is in gear. As soon as you pass the transfer case from 4HI into Neutral, the TC input shaft starts to turn. When the input shaft is turning, you cannot put it into 4LO because one shaft is turning and the other is not.
    If the trans is in neutral or park, then the trans output shaft (same as the TC input shaft) will not be turning and it will drop into gear.
    Also, you can shift from LO to HI while moving (slowly), but you cannot go from HI to LO unless you stop and place the trans in P or N. It has to do with gears meshing.
    krice118 likes this.
